Mopar flathead 6
Ketju osiossa 'Moottori', aloittaja sixmachine, 30.9.2007.
  1. Iskyn nokasta löytyi tämmöinen keskustelu. Ilmeisesti niitä on muitakin. Keskustelussa timkingsbury kertoo parista muusta:
    "Its too wild for the street and has an issue with creating vacuum. That pattern was modified by Iskenderian to make his #1023 cam for the 1/2 mile an long tracks dropping the duration to 250 degrees and its pretty wild for the street. tech specs - intake opens at 20 degrees and closes at 50 degrees, and exhaust opens at 57 degrees and closes at 13 degrees, Duration .250 and he reduced the lift."
    Inlet:
    Valve opens 20 BTC
    Valve closes 50 ABDC
    Exhaust:
    Valve opens 57 BBDC
    Valve closes 13 ATC
    Imu:
    180+20+50=> 250 astetta
    Pako:
    180 +57+13 =>250 astetta
    Keskilinja:
    Imu:
    250/2 -20 => 105 astetta
    Pako:
    250/2 -12 => 112 astetta
    Nokkien välinen kulma:
    (105 + 112)/2 => 108,5 astetta.
    "I run a modified version of the pattern you have, in my 1949 Plymouth running the 25 1/2" big block- Tech info - intake open 20 degrees closes at 58, exhaust opens at 58 and closes at 20 degrees. 258 duration .435 lift. Its a bit lumpy but will spin north of 6000 rpm."
    Inlet:
    Valve opens 20 BTC
    Valve closes 58 ABDC
    Exhaust:
    Valve opens 58 BBDC
    Valve closes 20 ATC
    Imu:
    180+20+58=> 258 astetta
    Pako:
    180 +58+20 =>258 astetta
    Keskilinja:
    Imu:
    258/2 -20 => 109 astetta
    Pako:
    (109 + 109)/2 => 109 astetta.
  2. Löytyipä vielä tämmöinen keskustelu, jossa on toi sama Iskyn nokkakortti, kuin aiemmin.
    Sieltä löytyy vielä yksi nokka:
